Back
Why doesn't my phone ring (corded phones)?
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
There are several things that can stop your phone ringing. Here are some things you should check: Make sure the ringer volume is not turned down or off. For instructions, go to the user guide for your phone................. ......
  1. Make sure the ringer volume is not turned down or off. For instructions, go to the user guide for your phone >
  2. Check that you are using the line cord that came with the phone. A different cord may not be suitable
  3. Check both ends of the line cord are connected and it is secure
  4. If your phone needs a power supply check the power is turned on
  5. Make sure the power adapter is plugged into a working mains power socket and to the phone
  6.  Check power adapter is plugged into a working mains socket and to the phone
  7. Switch the mains power off, wait five seconds and then turn it on again to reset your product
  8. Switch the mains power off, wait five seconds and then turn it on again to reset your product
  9. If you can, reset your phone to its factory settings. Find out if it is possible in the user guide for your phone >
  10. If you still can't fix your problem, contact the helpdesk for the model of phone. You'll find the contact details in the user guide >
Still having problems?
If you think the problem is with your BT line or service, you can test your line and do some quick checks with our landline troubleshooter >
Report and fix landline problems online
Thanks for your feedback
Submit
Need more help?
