Back
How do I get a PIN or a PUK code for my mobile phone?
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
We send out our BT Mobile SIMs with the PIN switched off, but you can easily turn it back on.
To do this, you'll need the original PINs:
  • PIN1: 5555
  • PIN2: 6666
To set up your PIN, go to your phone's user guide. It's usually in Settings then Security then Set SIM PIN lock.
It's probably best to change the default PIN to a 4 digit number that's easy to remember.
The SIM PIN only locks the SIM when your phone is turned off. For extra security, you can also set up a screen lock.
I've locked my SIM and need a PUK code
If you get your phone's PIN number wrong three times, you'll need a PUK code (it stands for Personal Unblocking Key).
Don’t try and guess it as you might end up blocking your SIM permanently.
You can see your PUK code by signing in to my.bt.com  >
Navigate to ‘Your Products’, then select ‘Manage’ within the mobile section. Click on the settings for the SIM plan you need a PUK code for, and then you will see the PUK code listed.
Thanks for your feedback
Submit
Need more help?
