Tells you what you need to know about getting BT 4K Ultra HD TV | BT
Here are some answers to help you
BT 4K Ultra HD TV -
BT TV HD channels and add-ons Find out which channels you get with the HD Extra and HD add-on on BT TV.
Setting up and using BT Ultra HD Find out how to set up your 4K recordable TV box, and what to do if you're not seeing Ultra 4K HD channels.
Ultra HD compatibility and set up on your 4K TV Check your brand of TV to find out about compatibility and set up for Ultra HD from BT.
Go back to: What can we help with?
