Back
BT TV user guides
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
Choose the correct user guide for the TV box you have. You can also see the Declaration of Conformity for the box here....
Choose the correct guide for the TV box you have:
If your box looks like this:
In standby with network connection
In standby with no network connection
Energy Saver
0.46 Watts
0.46 Watts
Always Ready
7.3 Watts
7.3 Watts
Smart Standby (default 1am-5am)
Energy Saver mode default 1am – 5am
Always Ready mode default 5am – 1am
Other box states
In Full Operation
Up to 8.4 Watts
Off
0.0 Watts
Time to switch from On to Standby in Energy Saver mode
80 seconds
Model number
MS-V2000R120-024F0-GB
Input voltage (V)
200 - 240 Vac
Input AC frequency (Hz)
50/60
Output voltage (V)
12.0 Vdc
Output current (A)
2.0 A
Output power (W)
24.0 W
Average active efficiency (%)
86.80%
Efficiency at low load (10%)
76.80%
No-load power consumption (W)
0.075 W
Core Device Software
++DFB
ATOP tool
avahi
Bash
BIND (Berkeley Internet Name Domain)
binutils
bison
bitstream
blktrace
BlueZ
Boost C++ Libraries
Broadcom/stblinux
Bustle
BusyBox
Bzip2
c-ares
Cairo Graphics
certifi
chardet
chrpath
cramfs-tools
cURL
D-Bus
dbus-glib
dbus-python
DHCP
DirectFB
DirectFB-DiVine
Dnsmasq
dnspython
dstat
e2fsprogs
elfutils
ethtool
eudev
expat
file
fio
flex
fontconfig
glib
glibc
GPT-fdisk
gSOAP
gst-fluendo-timeshift
gst-libav
gst-plugins-bad
gst-plugins-base
gst-plugins-good
gst-plugins-ugly
gst-vqe
gst-vqe
GStreamer
HarfBuzz
hattrie
htop
htop
icu
idna
inotify-tools
intltool
iostat
iotop
iozone-3
iperf3
iproute2
iptables
iptraf-ng
iw
Jinja2
jitterentropy-library
jpeg
json-c
json-glib
json-nlohmann
json-schema-validator
kaitai
less
libaio
libarchive
libc_modern
libcap
libconfig
libcurl
libdaemon
libdrm
libelf
libevent - an event notification library
libffi
libgcrypt
libgee
libgles
libgudev
libinput
libmng
libmpeg2
libndp
libnl
libpcap
libpng
libpthread-stubs
libsoup
libsysfs-2.1.0
libtool
liburcu-0.11.1
libwebp
libxkbcommon
libxml2
libxslt
libxslt
libyuv
linux-fusion
log4cplus - Logging Framework for C++
lz4
m4
module-init-tools
mongoose
mtd-utils
mtdev
ncurses
netcat
NetworkManager
nghttp2
ntpclient
openrc
OpenSSL
PCRE
pixz
pngpp
polipo
popt
procps-ng
PSI
psmisc
psutil
pyasn1
pyasn1-modules
pycurl
pygobject
Python
Qt
QtWayland
QtWebDriver
QtWebKit
requests
rng-tools
rpcbind
rsync
socat
SQLite
Squashfs
strace
sudo
sysklogd
sysstat
The FreeType Project
tremor
udev
urllib3
util-linux
Wayland
Wayland-protocols
Weston
wpa_supplicant
xkeyboard-config
XZ Utils
yaml-cpp
zip
zlib
Platform Software (UI)
asap
aws-iot-device-sdk
base64-js
bl
buffer
core-js
core-util-is
d
dayjs
duplexify
end-of-stream
es5-ext
es6-iterator
es6-map
es6-symbol
event-emitter
ext
fetch-mock
glob-to-regexp
ieee754
inherits
isarray
lodash
lolex
mqtt
mqtt-packet
mustache
node-libs-browser
object-assign
once
path-browserify
path-to-regexp
process
process-nextick-args
promise
punycode
querystring-es3
react
react-dom
redux
redux-logger
reinterval
rxjs
safe-buffer
scheduler
setimmediate
stream-shift
string_decoder
symbol-observable
timers-browserify
tslib
type
uri-templates
util
util-deprecate
uuid
webpack
websocket-stream
wrappy
xtend
Model: T2100/T2110 - 500GB Hard Disk Drive
Energy Saver
Always Ready
0.3 Watts
9.2 Watts
0.3 Watts
9.1 Watts
Smart Standby
Energy Saver mode default 1am-5am
Always Ready mode default 5am-1am
Energy Saver
Always Ready
0.3 Watts
9.2 Watts
0.3 Watts
9.1 Watts
Smart Standby
Other box states
In full operation
Up to 11.1 Watts
Off
0.01 Watts
180 minutes
In full operation
Up to 11.1 Watts
Off
0.01 Watts
180 minutes
British Telecommunications plc, London, E1 8EE
Company no. 1800000
Model number
MOSO MSA-C2000IC12.0-24B-ZZ
Input voltage (V AC)
200-240
50/60
Output voltage (V)
12
Output current (A)
2
Output power (W)
24
88.01%
83.11%
0.04
All BT TV boxes contain opensource software. For more information go to the Humax website and look for your TV box's model number.
For this model, select DTR-T2100/10
Model T2200 - No hard disk drive
Energy Saver
Always Ready
0.3 Watts
9.3 Watts
0.3 Watts
9.3 Watts
Smart Standby
Energy Saver
Always Ready
0.3 Watts
9.3 Watts
0.3 Watts
9.3 Watts
Smart Standby
Other box states
In full operation
Up to 9.5 Watts
Off
0.0 Watts
180 minutes
In full operation
Up to 9.5 Watts
Off
0.0 Watts
180 minutes
Company no. 1800000
Model number
MOSO MSA-C1500IS12.0-18E-ZZ
200-240
50/60
Output voltage (V)
12
Output current (A)
1.5
Output power (W)
18
86.52%
82.18%
0.049
Company no. 1800000
Model number
LITEON PE-1120-4UD1
200-240
50/60
Output voltage (V)
12
Output current (A)
1
Output power (W)
12
82.56%
NA
0.051
For this model, select DB-T2200/10
Model: T4000 - 500GB Hard Disk Drive
Energy Saver
Always ready
0.3 Watts
15.0 Watts
0.3 Watts
14.9 Watts
Smart Standby
Energy Saver
Always ready
0.3 Watts
15.0 Watts
0.3 Watts
14.9 Watts
Smart Standby
Other box states
In full operation
Up to 17.1 Watts
Off
0.01 Watts
180 minutes
In full operation
Up to 17.1 Watts
Off
0.01 Watts
180 minutes
Model: T4000 – 1TB Hard Disk Drive
Energy Saver
Always Ready
0.3 Watts
19.0 Watts
In standby with no network conneciton
0.3 Watts
18.9 Watts
Smart Standby
Energy Saver
Always Ready
0.3 Watts
19.0 Watts
0.3 Watts
18.9 Watts
Smart Standby
Other box states
In full operation
Up to 21.8 Watts
Off
0.01 Watts
180 minutes
In full operation
Up to 21.8 Watts
Off
0.01 Watts
180 minutes
Company no. 1800000
Model number
200-240
50/60
Output voltage (V)
12
Output current (A)
2
Output power (W)
24
88.01%
83.11%
0.04
For this model, select DTR-T4000
Get Adobe ReaderYou will need Adobe Reader to view PDF documents.
More help
The new TV help tool is available to all BT TV customers. When things go wrong, it can quickly get you up and running again.
Use the TV Help tool >
Thanks for your feedback
Submit
Need more help?
