Back
BT Mini Hub
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
We no longer sell the BT Mini Hub. If you're looking to improve wi-fi coverage in your home, then take a look at the BT Shop to see some alternative products.
Product details
Taking wi-fi even further, the BT Mini Hub Kit is a great way to extend broadband in your home.
Just so you know, this isn’t the 4G Mini Hub you get with BT Halo or with a data SIM plan. For more information see:
Learn about the 4G Mini Hub >
4G Mini Hub with a Data SIM plan >
Just plug into a power socket to create a new wireless network for those really hard to reach places.
The Mini Hub also comes with two Ethernet ports for a wired connection. It works with all our Hubs.
  • 11ac dual-band wireless technology with speeds of up to 867 Mbps
  • Faster downloads and online gaming
  • Uses your home's power sockets to create a secure wi-fi hotspot
  • Simple wi-fi connection at the touch of a button
  • Works with all broadband providers and with all of our Hubs
  • Two Ethernet ports for wired devices
  • Link with other HomePlug AV powerline adaptors
  • Uses latest AV2 technology for smoother streaming on HD and 3D TV
  • Secure wireless network - no configuration necessary
  • Pass-through socket
  • Need more? Plug in up to 16 Mini Hubs or Mini Connectors to extend your network even further
BT Mini Hub Kit
How to set up and get connected
For full set-up instructions check the user guide.
  1. Plug in the Mini Connector near your BT Hub
  2. Plug one end of the Ethernet cable provided into the BT Hub and the other end into the Mini Connector
  3. Plug in the Mini Hub where you have a wi-fi black spot. You can connect your devices to the Mini Hub’s new wi-fi signal or use its Ethernet ports
What an extended network looks like
Supersize your wi-fi
Documents
Get Adobe ReaderYou will need Adobe Reader to view PDF documents
Software
Download the latest software for the BT Mini Hub >
Need some help?
Chat to us
A quick way to get help, all day and every day. We’re here to help seven days a week between 7am and 11pm.
Chat to us now >
Get help from other users
Join the conversation in The BT Community Forum at www.bt.com/community >
Call us
If you need to talk, give us a ring on 0800 111 4567. We’re usually less busy between 12pm and 6.30pm. When you call, make sure you're next to your Mini Hub with a computer or device.
You can also call 0330 123 4567 from a mobile.
Thanks for your feedback
Submit
Need more help?
