Back
BT Broadband connection problems
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
If you're having problems connecting to your broadband there are some things you can do at home to try and resolve it. It will save time if you can try these first before calling us.
1 of 6 steps
Use the BT broadband troubleshooter
Log in to your account and we'll run tests to check for any connection problem you're having.
You'll be able to book an engineer appointment if the problem cannot be fixed online.
Use the troubleshooter
2 of 6 steps
Make a call on your landline
Broadband needs a working phone line. Check you can make a phone call and that there's no noise on the line. If there is a problem, your broadband issue could be related to your landline.
Try our landline troubleshooter >
    3 of 6 steps
   Restart your Hub
      Many connections problems can be resolved by turning your BT Hub off and on.
  • Press the Power button on the back until all the lights go off and wait for 5 minutes.
  • Press the Power button again until all the lights come back on. It may take a few minutes for the lights to settle.
     If this doesn't work check the status of the lights (see below).
4 of 6 steps
Check the lights on your BT Hub
The lights on your Hub give indicators about what the hub is doing and whether everything is working correctly.
If there are no lights, check the power cable is in firmly, and connected to the mains.
A steady blue means that the Hub is connected to your broadband. If you are still having problems try turning the device you are using - like a phone, tablet or laptop - off and on.
If the light isn’t a steady blue there could be an issue, but there are things you can do to help resolve it.
What the lights on your BT Hub mean >
Outline of BT Hub with blue light
5 of 6 steps
Power cycle your modem
Fibre customers might have an Openreach modem installed. This is a white box that connects to your BT Hub.
We’ve found that many fibre connection issues can be resolved by power cycling the modem – turning it off and on again in a controlled way.
How to power cycle the Openreach modem >
6 of 6 steps
Try your test socket
The issue may be with your internal telephone extensions, rather than the phone line itself. One way to check this is by connecting your Hub to your test socket.
The test socket is your main socket. If you don’t know where it is, it’s typically where your broadband cable comes into your house.
How to use your test socket >
Thanks for your feedback
Submit
Need more help?
