Back
Hybrid Connect
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
What is Hybrid Connect?
Hybrid Connect is the UK's first unbreakable wi-fi. With it you get BT's hybrid broadband backed up by EE's mobile network.
More about Hybrid Connect.
Setting up Hybrid Connect
You'll find instructions on setting up your Hybrid Connect in the My BT app.
Or you can download the set up guide.
More about setting up Hybrid Connect.
Using Hybrid Connect
When the light on your Smart Hub 2 is purple, it's using Hybrid Connect to connect you to the EE mobile network.
To find out how it works, what all the lights mean, and how to improve your connection, read our tips.
Tips for using Hybrid Connect.
Thanks for your feedback
Submit
Need more help?
