Back
Digital Voice: I have a problem with my handset
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
What problem are you having?
If your handset won't switch on, there are some quick and simple things you can check. Follow the steps for the handset you're using:
Advanced/Essential Digital Home Phone
  1. Check your batteries are in the handset correctly. They must be rechargeable as explained in the user guide
    You'll need to remove the battery cover to check this
  2. Make sure your handset is charged
    Put your handset into the docking station to allow the handset to charge. The screen should light up and will show if the phone is charging or not. We recommend you charge your phone for up to 16 hours when you first set it up.
    Battery charging
    If your phone battery was empty, please allow a few moments while it charges up enough to turn on
Other cordless handset
  1. Check your batteries are in the handset correctly and make sure your handset is charged
    Your handset's user manual will show you how to check if your batteries are inserted correctly, how to see if your battery is low and how to charge the handset
If your handset won't charge, check that it's correctly positioned in the charging base, that the base is connected to the power plug and the mains electricity supply is turned on. You could also try using a different set of rechargeable batteries. If this doesn't work, follow the steps below for the handset you're using.
Also see Digital Voice: How do I set up my service? >
Fix your Digital Voice service with our troubleshooter
Report and fix your landline problem
If we can't find a fault or fix the problem online, we'll give you the option to book an engineer appointment.
If you can't connect to your BT Broadband, you can also do all of this using your mobile internet connection.
Already reported a fault?
Track your fault, change contact details and appointment times using our fault tracking service >
Still having problems?
Visit our contact pages for other ways to get in touch.
Thanks for your feedback
Submit
Need more help?
