Back
How to change APN settings on a BlackBerry
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
Here's how to change APN settings on a BlackBerry.
  1. Go to Settings
  2. Select Network Connections
  3. Select Mobile Network
  4. Select APN
    Put in the following settings:
    • Access Point Name (APN): btmobile.bt.com
    • Username: bt
    • Password: bt
  5. Now press Save
To set the MMS APN:
  1. Swipe left to right
  2. Access The Hub
  3. Select Text Messages
  4. Select Menu (...)
  5. Select Settings
  6. Select Text Messages
  7. Select Advanced
  • APN: btmobile.bt.com
  • Username: bt
  • Password: bt
  • MMSC URL: http://MMS/
  • Proxy URL: 149.254.201.135:8080
  • Proxy Username: leave blank
  • Proxy Password: leave blank
  • Maximum Message Size: 307200
Make sure that all the settings are correct and then then click Save.
Thanks for your feedback
Submit
Need more help?
