Find out what the two different BT TV PINs are and how to change them.
Here are some answers to help you
PIN help on BT TV -
BT Mini Connectors for BT TV Everything you need to know about our BT Mini Connectors kit, which connect your BT TV box to your BT Hub without the need for wires.
Powerline Adapters and BT Mini Connectors user guides Everything you need to know about our BT Mini Connectors kit, which connect your BT TV box to your BT Hub without the need for wires.
Audio Description on your BT TV box Audio description describes what's happening on the screen. Here's how you can turn it on or off, or change the volume.
Go back to: What can we help with?
