Back
Dual-Band Wi-Fi Dongle 600 Windows software
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
To manually download the software for your Dual-Band Wi-Fi Dongle 600, click on the link for your operating system. Choose Run to install the software or Save to save and then run it later.
When you run the installer your screen will dim and you will be asked to confirm that you want to run the installation. This is normal.
Windows 10 >
Windows 8 >
Windows 7 >
Windows Vista >
Windows XP >
Note that if you're using a company laptop, you might need administrator rights to be able to install the software.
Thanks for your feedback
Submit
Need more help?
