Are the different BT Whole Home Wi-Fi products compatible with each other?
No, the Whole Home Wi-Fi products - Whole Home Wi-Fi, Mini Whole Home Wi-Fi, Premium Whole Home Wi-Fi and Whole Home Wi-Fi 6 are not compatible with each other. So you can't use Whole Home Wi-Fi discs with Mini Whole Home Wi-Fi discs, for example.
If you're having trouble deciding which one to choose, you can find out more from our product page >
What type of hub or router is Whole Home Wi-Fi compatible with?
BT Whole Home Wi-Fi products are compatible with all broadband hubs and routers with an RJ45 Ethernet port.
