Back
BT Whole Home Wi-Fi FAQs - System requirements
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
Should I turn off my hub (router) wi-fi?
There's no need to turn off your hub (router) wi-fi. Just remember on your devices to ‘forget this network’ for your hub (router), making sure you're connected to the Whole Home Wi-Fi network.
Screenshot showing Forget This Network
However, turning off your hub (router) wi-fi may improve your Whole Home Wi-Fi performance, particularly where there are lots of other wireless networks.
Does Whole Home Wi-Fi support Power over Ethernet (IEEE802.3af)?
No, Whole Home Wi-Fi can only be powered by the included AC adapter(s).
Does Whole Home Wi-Fi support multiple WLANs including a guest network?
Yes. Whole Home Wi-Fi supports both normal SSID and Guest Network WLAN for both 2.4GHz and 5GHz.
How many discs are supported on one network?
Eight discs are currently supported.
Thanks for your feedback
Submit
Need more help?
