Back
BT Smart Controls FAQs - General settings
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
How do I access camera settings?
In the BT Smart Controls App:
  1. Log in to the BT Smart Controls App on your device
  2. Tap the Settings button on the top right of the camera window
Where can I find the night vision settings and how do I control it?
  2. Tap the Settings icon next to your camera
  3. Tap Settings
  4. Night Vision is the first option available
Here you can turn the night vision 'ON' or 'OFF' or select 'Auto night vision mode'.
Tip: If you have your camera pointing out of a window, it’s best to switch night vision to 'OFF', otherwise you'll see a reflection of the infrared lights that allow the Night Vision feature.
How do I adjust the video streaming quality?
Your video quality is always set to 720p, however it's then compressed to make sure you don’t use up too much of your mobile data allowance.
By default, the video setting is set to Medium. To change this follow the below steps:
  3. Tap Settings
  4. Scroll down to Video Bit Rate
  5. Change to Low, Fair or Good
Alternatively, this setting is available at the top right of the screen when viewing the camera.
If you've a data cap of 1GB or less, it's recommended you set this to 'Low' to avoid using up too much of your mobile data allowance.
How do I access the live camera stream?
  2. Tap on your camera
  3. It will then load the live camera stream
Within the Smart Controls 3.0 update, we introduced a quick-view feature which allows you to start the camera feed without access to melodies, camera panning or talk back features. It can be activated in the dashboard by tapping the play button (marked Quick View) on the bottom left of the camera preview. If you would still like access to all of the camera features, just tap on the camera image.
Can I monitor the sound without keeping my app open?
Yes, this feature is available and is called ‘Background Monitoring’. It can be a useful feature if you've placed your device in a baby’s room or nursery.
  2. Tap Settings
  3. Turn ON “Background Monitoring”
  4. Select the camera you would like to view
  5. Press the Home button on your device to put the app in background mode
If you no longer want to hear the background noise just fully close the application.
How can I take a picture or recording from a live video stream?
  2. Tap your camera to view the live video stream
  3. Tap the screen so the icons appear
  4. Tap the camera icon to take a snapshot or record a video
Screenshots and recordings will be stored on your device. iOS devices will store these in Photos, and Android devices in a folder named after your username. If you can’t see the folder on your Android device, try downloading a photo viewer app from the Google Play store.
How do I activate 2-way talk mode, play melodies or pan the camera through the app?
  4. Tap the microphone to activate the 2-way talk functionality, tap the music note to play a melody or tap the <o> button to pan your Smart Video Baby Monitor device
How many cameras can I add on one App?
You can add up to ten cameras to your BT Smart Controls App.
Is there a maximum number of cameras that you can set up on any single user account?
You can add up to ten cameras to any single account.
How do I factory reset the camera to its original settings?
For Smart Home Cam:
  1. Hold down the "Link button" on the back of your camera
  2. Switch the camera to OFF, whilst still holding the “Link button”
  3. Whilst still holding the "Link button", switch the camera on again
  4. Wait for around 20 seconds until you hear a loud beep, then release the “Link button”
The camera has now reset to factory settings. Wait a couple of minutes for it to restart.
For Smart Baby Monitor:
  2. Wait for around 10 seconds until you hear a loud beep, then release the “Link button”
The camera has now reset to factory settings, wait a couple of minutes for it to restart.
How do I change the name of the camera within the Smart Controls App?
  3. The name of your camera appears in the “Details” section where you can change it
  4. Tap the pencil icon and enter the new name
  5. Once done tap Ok to save the changes
How do I delete a camera?
  2. Tap Settings icon next to your camera
  3. Tap Bin on the top right of the screen
How do I change the time zone of the camera?
This is automatically set when you first set up your camera. If you think what's being displayed for motion events is incorrect, you may need to factory reset the device and re-pair the camera to the application.
How do I rotate the screen if I want to mount the camera upside down?
There can be situations where you'll need to rotate the live stream. For example, if you mount the camera to a wall upside down, by default your stream would be upside down as well.
To rotate the live stream:
  3. Tap Settings
  4. Set 'Ceiling Mount' to ON. This will rotate your camera by 180 degrees
Thanks for your feedback
Submit
Need more help?
