All our Hubs have ports (Gigabit or Ethernet) on the back for you to connect your devices using wires.
Our latest Smart Hub 2, Smart Hub and BT Hub 5 have four Gigabit ports. These ports are 10 times faster than Ethernet ports so you always get the fastest connection.
The BT Home Hub 3 and 4 have Ethernet ports so you can connect via Ethernet.
The Smart Hub 2 also has a USB port which you can use to charge phones or tablets.
There's also a Phone port. This won't work with your current PSTN phone service and will be used for future products.
If you want the fastest internet connections you should think about getting our latest Hub >
Still need help?
For more advice on how to get the best from your BT Hub, visit Help for Hubs >
Or, if you’ve got one of our older Hubs why not buy our latest BT Smart Hub? >
