Back
How to change APN settings on a Windows Phone
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
Here's how to change APN settings on a Windows Phone with Windows 8 or Windows 7 >
Windows 8
  1. Swipe right to left to show Applications List
  2. Select Mobile Network
  3. Ensure data connection is set as on
  4. Go back to the main Applications List and select Access Point
  5. If EE is showing within the list, tap on it to make it active.
  6. If it isn't showing, select Add
Put in the following settings:
  • Connection Name: Internet
  • Data Type Preset: set to Default
Setting up the Internet APN
  • Access Point Name: everywhere
  • Username: eesecure
  • Password: secure
  • Proxy Address: leave blank
  • Proxy Port: leave blank
  • Network Type Preset: IPv4
  • Authentication Type: preset
Setting up the MMS APN
  • MMS Access Point Name: eezone
  • Password: secure
  • Proxy Address: 149.254.201.135
  • Proxy Port: 8080
  • MMSC Address: http://MMS/
  • Authentication Type: PAP
  • Maximum Message Size: 307200
Make sure that all the settings are correct and then click on the Tick on the bottom of the screen to save and restart your phone.
Windows 7
  1. Go to Settings
  3. Select APN Add
  • Name: Internet. (You'll see a message: "Make this my current APN". Tick this box)
  • APN: everywhere
  • Proxy: leave blank
  • Port: leave blank
  • Password: secure
Setting up MMS
You'll also need to set up your phone for multimedia. Scroll down the page to get to this.
  • Port: 8080
  • Password: secure
Make sure all the settings are correct then click Save followed by Confirm.
Thanks for your feedback
Submit
Need more help?
