Back
Learn about 4G Calling
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
4G Calling means that when you make or receive a phone call, your phone will stay on 4G so your internet doesn't slow down. That means you can use data at 4G speeds even when you're on a call. Sounds simple, but you'd be surprised how few mobile providers will let you do this.
Find out more about 4G Calling >
  • With 4G Calling your calls now go over the 4G network, which makes them crystal clear between compatible phones
  • 4G Calling is now available across the whole of BT's 4G network
If you're using Wi-Fi Calling, 4G Calling means your calls will seamlessly hand over between wi-fi and 4G.
Learn about Wi-Fi Calling >
BT Mobile will no longer be selling BT mobile phone, SIM and Family SIM plans to new customers.
What do I need for 4G Calling?
It's available to anyone with BT Mobile - whether you've got SIM only, a Family SIM or a BT Mobile phone plan. You'll need a compatible device with the latest software.
4G Calling on iPhones
  1. Make sure you have an iPhone 6 or later model and you have a mobile plan with us
  2. Check that your device's software is up to date. You'll need iOS 11.3 or later
  3. To do this, go into your phone settings, tap Software Update and install the latest update if available
  4. You're now ready to use 4G Calling as this is switched on by default
4G Calling on Android phones
  1. Make sure you use a phone that was bought from BT and you have a mobile plan with us
  2. Check if your device supports 4G Calling. You can easily do that with our MY BT app (just scroll down to the "Phone connectivity" section). Or log into My BT, go to Your Products and the Mobile section
  3. Update your software. For most Android devices you need to tap Settings from the dropdown menu, scroll down to "About phone" and tap Software Update. You're now ready to use 4G Calling as this is switched on by default
Check if you have coverage in your area >
Need more help?
Using 4G Calling >
Thanks for your feedback
Submit
Need more help?
