Back
BT4500 Big Button
Big things are coming at EE
BT and EE are part of the same family, and big things are coming for the EE brand. But this won't change any of the BT services you have with us today. Read more about the changes coming to EE.
Product details
Cordless telephone with answer machine
  • Easy to read 1.8" full graphic dot-matrix display with amber backlight
  • Hearing aid compatible with Amplify button to boost volume when you need it
  • Avoid Nuisance or Unwanted Calls with options to block calls by specific numbers or certain call types*
  • Handsfree speaker
  • One touch button to record live conversation
  • Up to 60 minutes answering machine and live conversation recording time
  • Visual voicemail allows you to see who has left a message and choose those you wish to listen to*
  • Save up to 100 contacts that will automatically synchronise between handsets (twin pack or more required for contact synchronisation)
  • Available in single, twin and trio packs
  • Up to 300m range
  • Up to 16 hours talk and 180 hours standby time
* You need to have a Caller Display service from your network provider to block nuisance calls and for Visual Voicemail feature. Charges may apply.
BT4500 Big Button
Recycle Logo
Documents
Thanks for your feedback
Submit
Need more help?
